I currently have a PMU24 that has internal logging. If I add and additional PMU16 do I need to get the DL version to log it’s parameters or can I log them over CAN with the PMU24?
Yes you can, but you will run out can bus inputs if you try to import all pmu16 can messages. So you need to decide what do you want to log from 16. Also if you want to log functions etc, you need to make custom can messages (it´s easy thoug).
Thats not a problem, i dont want to log every parameter, probably just voltage and current incase theres a problem
