ADU,CAN key board , EMU, and USB to CAN where i connevt CAN1 or CAN2
USB to CAN, ADU and EMU must be connected to CAN1
CanKB, connect it to CAN2 so you dont need to change kb can speed with light client. If you need kb buttons to EMU, you can forward those messages to CAN1
ok thank you.
And there need resistor end of the CAN2 ?
You can enable CAN2 resistor in ADU settings
Best practice is always use daisy chaining with both ends terminated.
pls tell me about wiper wiring and setup .
I have a similar Situation with the switchboard. I tried a couple of things forwarding a channel to the PMU.
My switchboard is connected to ADU via CAN2. EMU, ADU,PMU are connected to CAN1.
I simply like to add a switchboard button in an existing pmu function to conttoll a fan. But I cant see the switchboardbutton from the PMU. Only the ADU buttons.
I also tried to create a function in the ADU an exported it to the PMU, hoping the PMU will get the message from the switchboard.
But wenn I read the upper description I guess I overcomplicating and its much easier.
