Can Problems ADU
So wired my PMU and ADU to can system. Both on Can 1 and can 2 with blink keys. 120 ohm resistors in place
Use PC and through my wiring I can connect to both units. However when I use light Client I can only see the ADU.
And I can’t get info from PMU up on the dash.
Quite new to all this “Help please” :grin:
PMU is not compatible with Light Client (link, page 3).
To say more about your communication issue between ADU and PMU, we need more information. Please share your projects from both devices, and we will try to help you.
That’s great thank you. How do I go about sharing project. Sorry for dumb question Learning as I go :grinning_face_with_smiling_eyes::grin:
Hey,
your files if you saved them should be in the documents folder under ADU and PMU. Inside these folders you will find subfolders with the “serial number” or “name as you set” of your devices.
Then you can attach them here with the upload button as in the picture below
