At this moment it is possible to connect these inputs to “Exhaust gas temperature” channels only. However you can create a Logical Function in Project Tree panel. As a channel use “Resources Precision analog # Voltage”. Please keep in mind two things:
- To change pullup/pulldown you need to temporarily set “Precision input” as a source for “Exhaust gas temperature” in Sensors and choose proper resistor option. Then change the source to the previous setting.
Don’t set “Precision input” for EGT unless it is a EGT sensor. This value is used for fuel corrections!- For now precision inputs have 0-255 mV measurement range. It would be easier to use a switch connecting the input to the GND. In such case set “10k pullup” for the input.
When configured “correctly” per above, should the sensor still show up on the Input Assignments table like so? (In this case I followed the instructions for setting the 10k PullUp for 1 and 2)
Even though the EGT sensor is set back to None?
Would it be possible to add pullup/down configuration (and any other physical parameters) to the input assignments table so that the status of everything is easily verifiable?
