Audi TT BUB VR6 - Cruise control, AC Idle up, and fuel pressure settings
Easy stuff first. The Audi TT VR6 BUB uses a rear mounted FPR with a static fuel pressure of 4 bar. I’d rather not have to run a return line and switch to a rising rate fuel pressure reg.
Running V3’s latest firmware.
What can I do with Fuel Pressure Regulator in Fueling-General? There isnt an option for a static fuel pressure/dead head fuel system.
Next, cruise control setup for the Set/Cancel. Resume and speed up and down. Is there a wiring diagram for how the EMU Black BUB that will tell me what inputs to use for these?
Last question… How do I up the throttle opening with the DBW throttle when AC is turned on?
Thanks,
Ian
Baro referenced = atmosphere referenced, a deadhead system with no MAP reference.
Enter 400 kpa as your base pressure
Idle parameters = AC idle increase Value
This adds rpm to the idle rpm target when AC is active.
Thanks that makes sense. So many settings in these ecu’s. They need a search box at the top like the Haltech NSP software has.
It was added in V3 firmware and it’s in pro, so they agreed lol
