Autotune no cells corrected
Hello
Maybe someone can tell me what am I doing wrong?
From a one hour long log, all I get is 13 cell corrections in Autotune, all around the idle region.
I drove it on the highway and made sure to be very constant. Acc. enrichment is turned off.
You have to select the cells yo want to adapt. Then press S for full adaptation or Alt-S for 50% adaptation.
yes, I know that, there is nothing IN the cells after a one hour drive…
If you share your file and log, i can take a look.
Here is the log
12-07-2026 autostrada.emublog3 (3.5 MB)
I have the same sytuation , 10min driving and only 12 cele on green.
somehow it doenst see enough samples i think. interesting.
I think there is a setting for transient delay when you set up the auto tune. Been a while since I used mine. If the delay is too long it will exclude the samples. I might be miss remembering, just a thought I had hoping it helps.
It does have a transient delay, I set it to the minimum possible, 100ms, still nothing, I also have acc. enrichment off.
