Black + Ti Automotive controller kit how to connect?
Is it possible to connect this device and configure it?
If possible how? In the fuel pump settings you cannot specify pwm….
V2 or V3 firmware?
V3 will be more tidy; you can use a function to enable a PWM signal and then create a table that is MAP vs RPM etc.
V2 is possible using a virtual parametric output and PWM table. Create a parametric output that’s active when the fuel pump is on, use the “activation virtual output” parameter in the PWM parameters to enable the output. Make sure you’re on the latest firmware
thank you very much!
I have v2
Im going to try switching to v3
Please me know if updating to v3 will cause the settings to be lost.
There is an importer feature but you’ll have to still do some of it manually as V3 has strategies that don’t exist or are fundamentally different then V2
