Bluetooth for EMU PRO 8?
I want to use my tablet as a dash like I can do on EMU BLACK with the Bluetooth module.
But is this also possible with EMU PRO 8?
Does it have Bluetooth built in or is it possible to use the Bluetooth module for it?
The description of the Bluetooth module seems like it only mentions support for EMU BLACK.
It is on TODO list.
Artur
Is there an estimated date on that?
I’m deciding ECU for a build that should be ready this summer, and using an Android tablet is a must.
EMU PRO will use our existing BT-CAN module.
We will add the support in the EMU PRO before summer for sure.
Thanks, so it would be the exact same module as EMU Black uses as I understand it.
Thanks, having this forum is great!
Yes. The same modules that BLACK uses now will be compatible (the CAN version).
@Mike Support for the BT CAN module has been added in version 103.
Thanks for keeping me updated, this really shows the value of this forum!
hijacking a thread to keep all the BT info together.
is there a guide how to get this working on the pro? i have wired the unit up to suit but the guide were all written for the black and classic, yet to find an updated guide how to config correctly.
have the BT Can adapter connected to the can switchboard as it needs to run at a slower rate of 500k and my canswitch board is running at 1mb
my local rep told me that the EDL-1 wasn’t compatible with the pro 8 so we have installed the non serial can-bt adapter for an additional screen.
unit is powered up and flashing red, have been able to find the device on the ecudash3 app but i think it requires config on the pro end?
I am not sure what you mean by this.
All CAN devices together must be set to the same speed.
You have to enable the BT stream and select the CAN bus where the module is connected.
obraz
there are two can streams? i have managed to get it working by ticking the box and starting the app and then connecting via bluetooth.
thankyou again for your assistance!
Yes, there are two streams.
One is the general stream used by multiple devices like ADU and PMU.
The second one is dedicated to the BT module.
