Boost va map difference…
Boost vs map difference?
Can somebody explain this, or is there a fault in the programming?
When the map reads 220, the boost channel reads 71…
Boost controll gets unhappy with this :slight_smile:
Fw / sw 3.037
Best regards
Einar
Norway
boost is MAP - baro.
please check your baro configuration
just remember that you are no longer on map :smiley: i missed that one and boosted 3,5bar at the first run :smiley:
This got me as well, thought I was targeting 10psi, but in reality was Targeting 25psi, straight to overpressure fuel cut, 25 on a standard wheelbase cbr1100 is interesting to say the least :laughing:
