BOV/Recirculating valve
Is there any intention to add a section under boost for BOV control? It seems like an important thing to have now that everything is moving to electronic control.
I understand that this could probably be done in parametric or functions, but there’s not a whole lot of explanation to what each channel actually means or how to get it to act how we want it to.
For example if I want to control an electronic BOV, could I use the “TPS rate” channel to cycle the BOV for more or less duration based on ONLY a negative change % and not factor in positive TPS rate changes? That way the BOV can cycle under partial lift as opposed to looking for full lift.
On that note, can you even cycle an output in V3? As far as I can tell its just on or off.
Maybe I’m just over complicating this whole thing, and if that’s the case, could someone please assist with getting a function to control an electronic BOV so we can make it a sticky and everyone can use it? Thank you.
