Hey,
Is there a way to enable the CSW V3 Pullup Resistor without the Light Client?
And if I enable the Pullup Resistor in the CSW V3 what Ohm value I have to put in the Temperatures Sensor Config?
Regards
Have connected 1kOhm in and configured over the temperature configurator.
I get now readings but I think they are too low.
So my question is, what could be the problem?
Do you have the 20-50k pullup turned on or off in the canswitchboard? You will want it turned off and only use your 1k or a 2.2k pullup. Remember to configure your sender with the correct pullup. If you need help calculating the sensor voltage, you can use the following calculator Ballenger Motorsports - High Performance Electronics
How can I turn the internal resistor off?
The resistors are programmable in LightClient
