Hi, can someone confirm if this professional paint schematic would work in my toyota corolla IX 2004 1.6vvt-i. It has differential VR trigger wheel sensor and its the part I’m most concerned about.
Thanks in advance
did you get this working ?
Yes, it’s working in piggyback mode. Also another connection i made that’s not mentioned on this schematic is vss(vehicle speed sensor). I’ve cut the signal wire running to the ecu, plugged DET3 in between using frequency in/out pins.
can you please share config ?
Unfortunately i cant, im on holidays without my laptop, sorry
