Crank and cam sensors wiring
Hello everyone,
Im wiring an EMU PRO, but have concerns about the wiring arrangement because i have a VR and a Hall sensor.
I have a VR crank sensor, and im wiring pin #1 digital input for (+) trigger signal and digital ground for (-) trigger signal.
For the Hall sensor i assume that it can be wire, pin #2 digital input for (+) trigger signal, digital ground and 12V positive.
My main concern is on the hall sensor ground. Is it digital or analog ground?
I will appreciate your help.
U should put it to digital ground.
But in general it doesn’t matter…it will work on any grounds.
Thank you very much!
