Custom color presets (or textures) - rpm bar
Is it possible to create your own ‘color preset’ for a simple RPM bar? If so, could some please explain how to do it? Also, what is the ‘custom texture’ used for, I could not make anything work with that.
You need to set Color preset to Custom texture (128x1 RGB565), which tells you which format is supported.
Now you need to make your own PNG image with your preferred colors, it must be 128x1 in size.
Click on the three dots button on the right side of the Custom texture field, choose “Show textures” on the right side of the opened window and double click <Add custom texture>.
Select your PNG file and set the Format to RGB 565.
Now select the added texture, click OK and that’s it.
Here is an example:
Thanks for clarifying, I had all the steps done but missed the ‘format’ drop down when adding the texture!
In case others are interested in a variation, you can use this
green/yellow/orange/red RPM bar 9000
