Hi, Im new to ECU master and i cant seem to figure out sensor calibration tables.
I have an excel file for voltages for a user defined sensor with the pullup needed.
Is there an easy way to input this data into the table (copy and paste) or do i have to input each value individually
After configuring the sensor input source in “Sensors” section you would find the calibration table. On an X axis set the sensor voltage and fill the corresponding temperature values.
Alternatively you can use a sensor wizard. Right click on a table (not an axis) and choose “Run temperature sensor wizard”.
You can use one of the predefined sensors or use an “User defined” option and fill the values below.
