Hi, can someone suggest hot to set up DBW on IDLE, I’m having a bit of problem when blip my throttle over 3000RPM (clutch disengage ) RPM quickly drop to 600-650 RPM then they bounce up to my idle target 850 after witch Ramp Down Activate and rise up RPM to 1100-1050 RPM and slowly drop them down to 850 RPM, I have been playing for over 3 hours, and I can’t figure this out . Thanks
Log your idle states for what control is active when this is happening. This will help point the way as to what control is doing what and when.
Please post the project and the log file.
The most common reason is incorrect base air flow and armed air flow settings.
M54B30 G30-770.emupro (31.3 KB)
idle 2.emuprolog (520.4 KB)
I manage to get somehow a bit better, but I am still not very happy, When I use too much of Armed state, from time to time it will stay at high rpm +_1200RPM, I did set up minimum DBW Target, I would like RPM to drop gradually, so after a blip of throttle stay at 1200 rpm and then slowly drop to base target. Thanks
