Internally, (on EMU Pro 8) what is the difference between the C29 Analog Ground, the A20 Digital Ground, and the B9 “USB” Digital Ground? Are they isolated from each other in any way or is there something special about the Digital Ground (or, if I’m not using the USB logging on ECU, the USB Digital Gnd?)
I ask because I am trying to decide if I need to splice the single Analog GND across 100% of analog circuits or if it would be possible to use the USB Digital GND for the Throttle Body TPS sensors without any negative consequence.
