This can be applied to all dimming, if possible. Is there a way to make keypad and adu led dimming control a selectable source? The adu brightness is easy to handle by expanding it to 3d. The others are just single numbers. I understand the keypad has already alternative brightness.
In the upcoming ADU release (available in a few days), we have added the ability to control the can keyboard brightness using any channel.
The brightness of the LEDs is tied to the ADU brightness, so you can manage it through that setting.
However, I may not have fully understood your request. Could you please provide a more detailed description of what you’re looking to achieve?
I was referring to a way to use an external table or function.
That’s an interesting idea like if the headlights are on dim the buttons on the keyboard?
This is something I had asked for previously, so I am glad its being implemented. Most GT3 cars have a rotary for dimmer, as different drivers have different preferences for the display brightness.
Keep Up the good work.
