Duratec 2.0 non vvt
Hi
Has anyone used the Emu Black and PMU-16 on a Duratec 2.0 Non VVT Turbo. I am after a base map to get me started if anyone would be willing to share with me.
Surely someone out there has this same set up that would be willing to start me off. Please if someone would be willing to share
Hi Scott,
I can help you up to atmospheric pressure, my N/A Duratec 2.0 cable throttle non-VVT calibration gets you from idle to 100 kPa (as a guide) if that’s any use to you?
Just use the injector Wizard if you’re running bigger squirters than my Green Giants, then reference some boosted K20/B16 VE & ignition tables I hold to get you the rest of the way (starting point only).
Dave.
