Is possible to use a map sensor for secondary trigger? I can’t find the option.
Many thanks!
Many thanks!
I have replied on FB. You need to connect it to the secondary, then check with an oscilloscope what the actual voltage is there. Then, use a VR type of sensor and set the threshold correctly. im using this on a sidecar with a Triumph engine. Make sure you disable cam sync above 900 rpm, for example. alternatively you can splice sensor on digital and analogue and use emu pro software for logging. I just had a loom already made and booted, so therewas no option to splice in.
