Hi everyone.
I would like to know im using the Emu pro8 ive Got the 12 button keypad can this work directly with the EMU PRO8 without having a PMU
Hi everyone.
Hi jan,
Thank you for your reply
We can configure the buttons and change colors but it doesn’t want to communicate to Emu to allow power out to the relays where do we configure it in the Emu
Kind Regards,
Justin Els
010 021 0120 / 079 839 4190
Justinelsgopro@gmail.com
After you setup the buttons how you like, latching, non latching, radio, indicator…
If you are wanting just something generic to trigger relays, you use custom outputs and assign the button state. Here I have assigned button 1 to aux 1 and is triggered by button 1 and its latching state.
What are you wanting to use the buttons for?
Hi Jan,
I trust you are well
I have a question on my Emu pro8 we can’t get the injectors to pulse it gives a pulse width but no negative to injectors
Kind Regards,
Justin Els
Hi jan
When do a output on the injectors they work fine When cranking the injector positive is present all the time yes we dont get a injector pulse and log does not show a fuel cut of any kind
Kind Regards,
Justin Els
Your original post seems to be regarding a keypad.
Your last 4 posts appear to be a completely different issue relating to injectors.
Maybe start a new thread with your new problem???
