Hi, Is it possible to setup a can bus transmit using the Haltech CANX file for pmu to send data to a Haltech IC7 dash?
No, currently, CANX can only be used for the received data.
But it is something we want to add as a feature.
For now, you must manually set up CAN export for each channel.
We can also add the Haltech stream as a communication preset for future updates.
Thanks, a Haltech communication preset would be handy.
Does this mean that the ic7 can send data direclty to an emublack via can? and not jsut the other way around?
I would like to know this as well
