🐞 eDash Beta – Bug Reporting & Status
Updated bug report
Tried:
  • Samsung S7 - Android 13
  • Iphone 17 - IOS 26.3.1
  • Onn tablet pro - Android 11
App: 0.0.43
Emu black, v3 3.061, 3.064 (updated for this retest)
EDL-1 1.25 and 1.26 (tried both)
Issue
  • None of the devices ever see EMULOGGER on the eDash app Rescan screen
  • All devices see EMULOGGER on the native bluetooth pairing screens
    • Pairing and clicking them does nothing, EDL stays flashing the blue led
  • Using a Fire 7 tablet, attempting to use RealDash on it works, blue led goes solid
    • Havent been able to install eDash on it due to issues on the store
  • On the ONN device (android 11), i always get the "Permission denied, Bluetooth and Location permissions are required to scan and connect to BLE devices” error
    • Seems android 11 has a different permission and the app is not seeing it, permission screen on the android settings does not show a Nearby devices or bluetooth permission to be granted to any app.
  • EDL file, yes the mac and BT mod values are empty
    • EDL Firmware: 1.26
      Bootloader version: 2
      Bluetooth module:
      MAC addres:
Ive spent several hours playing around the devices and versions etc, no luck.
Device: iPhone 14 Pro
iOS: 17.2
ECU: EMU Black Plug-In ECU for 1.8T
Connection: EDL-1
Issue: Can’t find the device in the app, but the phone is connected to it via Bluthooth
EDL-1 firmware is 1.26
ECU firmware is 3.064
Could you please delete edl info file from the card, put it in edl and then check the data again?
Then should be bt module name
I have formatted the sd and deleted the file several times, even after reflashing 1.25 and 1.26 trying to get them to populate.
Sometimes i get no data at all, most times i get the partial empty strings i posted. If i highlight the text in the file, i can see empty spaces on both variables (18 spaces on the mac, 50 spaces on the BT module)
if theres a way to enable extended logging/output, im willing to flash and post the log
Flashing 1.25 gives me this
EDL Firmware: 1.24
Bluetooth module:
MAC addres:
Flashed 1.22 and got this:
EDL Firmware: 1.22
Bluetooth module firmware version: +BOLUTEK Firmware V2.2, Bluetooth V2.1
Bluetooth module mac addres: AB:53:86:34:3A:01
Flashed 1.26 again, same as before, lost the variables.
@DIMITRIS_ECUMASTER @LopinRD -
About problem in Android 11.
There is different permissions model in Android 11 than in newer Android versions. Developers are going to fix it in the next app version
Have readout the file:
EDL Firmware: 1.26
Bluetooth module:
MAC addres:
Thank you for the feedback!
You have BT V2.1 that doesnt support BLE Gatt protocol.
We will add SPP protocol support soon.
I will check what is an issue with edl info file in new firmware.
It’s resolved in firmware 1.26, so update please to fix this issue :slight_smile:
EDL Firmware 1.26 - eDash Open Beta - Ecumaster Community
I have already done. It works fine. THX for reply!
OH, ive had this EDL for a few years so let me ask, this version of the EDL logger hardware does not support the BLE protocol, if i get a new EDL it would work?
If support for it will be added afterwards might be a good idea to make a note on the manual about the EDL logger versions so people are aware and if support is coming to just hold for a bit.
Thanks for the response, let me know if i can test/help in any other way.
We should be able to add support for SPP prtocol soon, so you dont need to change the EDL to new one.
Mine is also a old one that dont seem to work​:sad_but_relieved_face:
Device:Lenovo Tab M9
Android: 13
App build: V 0.0.4
Ecu: Classic v 1.227
Connection:Ecumaster bt module
Delay of Seconds from all Parameter.
First five Seconds Data is in real time than IT delays more and more
  • Device model : Atoto S8
  • Android 10
  • App version: downloaded today. I didnt note It.
  • ECU model EMU Black v2
  • Connection type EDL-1
  • Short description of the issue
Hi! I recently installed the edash app on my Atoto S8 to test it out. I’ve a problem with the bluetooth conection :
“Permission denied. Bluetooth and location permission are required to scan and connect to BLE device”
I tried to grant permissions through the Android applications section, but the option to grant it doesn’t appear.
While we’re on the subject, I’d like to ask about the signal range of the EDL-1 module.
Currently, I have to position it with the SD card slot facing the back of the ATOTO device At a distance of 5 centimeters, because otherwise the signal is too weak and it can’t connect It to use the emudash app. This makes accessing the SD card impossible, as I would have to disassemble Part of the dashboard to access it.
I don’t know if it’s a problem with the emudash application or the EDL-1 module. I hope this improves with the edash app.
Unfortunately, your Android version is not supported.
Play store is listing Android 7+
There are millions of units that are android 10 being used every single day. Can we please get version 10 of android to work this is one of the reasons why I bought emu MU black.
I like my RealDash quite frankly, I would rather have E --dash work since the last three versions really struggled in this category . This is also for aToto S8.Thank you
  • Samsung S24 Ultra
  • Android version 16
  • App version 0.0.43
  • EMU Classic 1.227
  • Bluetooth module / BT Module
  • Short description of the issue:
App don’t show device, phone and old emudash app don’t have this problem
Also it would be great to run this app on Android 9!
First of all, thank you for your response.
It’s sad to read that.
As the others users have said, the vast majority of Android radio units use Android 10 or even earlier.
It would be a shame not to be able to enjoy the application, as it was one of the things that made me decide to buy the Emu Black and the EDL-1.
I hope it’s reconsider it
Thanks for all.
PD: it’s normal that bad signal that I have with the EDL-1?
At the moment, eDash officially supports Android 11 and newer, which covers the large majority of active Android devices. This decision is mainly related to Bluetooth and system permission changes introduced in newer Android versions, which significantly improve connection stability and security. Supporting older Android versions increases development complexity and can negatively impact BLE communication reliability.
We understand that some Android head units are still based on Android 10. We are reviewing possible options, however at this stage we cannot guarantee support for Android 10.
