"I downloaded and installed the app, but I’m having an issue where I can’t see the data on the screen. Do I need to adjust a specific setting for this???"
Please specify your setup:
- Device model (e.g., iPhone 14 Pro, Pixel 7, Samsung S23, etc.)
- iOS / Android version
- App version / build number
- ECU model (EMU Classic / EMU Black / EMU Black V3 / EMU PRO)
- Connection type (EDL-1 / CAN BUS - Bluetooth module / BT Module)
We can’t help you without that info.
Samsung s24u ecumaster black bt modul version 0.0.43
I had a go at it yesterday with no luck, the app wouldn’t discover the device
Device model: Samsung A26
IOS / Android version: UI 8, Android 16
App version / build number: 0.0.43
ECU model: EMU Black V3.064
Connection type: EDL-1 V1.26
Ive always had issues with the Bluetooth connection on this EDL, it would only very occasionally actually connect and show data on the old app. But I was optimistic about all the work that’s been put into the V3 and the new app so gave it another go.
Other than not connecting I noticed that all the EDL data in the V3 software data logs show nothing “EDL connected: NO”
The data logs have always worked fine saving to the SD card. Green light flashes indicating logging and the blue light has a slow blink.
If there’s anything I can try let me know, this is my personal car I’m happy to spend some time on it - I would like to sell more ECU master products at work as they’re good value, but at this point I still personally find Haltech more streamline which is better for business so I usually recommend them
iPhone 11 Pro Max
IOS 26.3.1
Ecumaster Classic
EMUBT
Ошибка: EMUBT не поддерживается телефоном. Хотя в программе есть подключение по блютус.
