EJ20 Ign and Inj phase settings
EJ20 Subaru Injection and Ignition phase settings.
Engine won’t start on any settings.
CAS - 6 tooth
CAM - 7 tooth
Firing order 1324
Coils on plug - wired Coil1 - Cyl1, Coil2 - Cyl2 and etc…
Injectors - wired Inj1 - Cyl1, Inj2 - Cyl2 and etc…
I’ve find that only on ignition offset 3 engine try to grab the fuel. But it won’t start.
Ignition offset 2 - fires in exhaust.
Ignition offset 1 - fires in intake.
More over, some how strobe light showed TDC mark spot on when I set ignition offset to 1.
Any help? I need settings for Ignition and Injector phase.
Thank you.
Files attached in the drive.
Subaru 3G.emub (145.4 KB)
https://drive.google.com/drive/folders/1ztKBX-V0msZgBegIc7iCxniNfbnAcgcv?usp=sharing
Solved!
Changed trigger to rising edge, and brupt and first try.
Closed case.
