Hey, I created a base file for a EJ20 3 cam sensor engine using a V2 map settings that started up and was running fine. Looking for help on what I may have configured incorrectly. I attached both a scope of rising & falling trigger edges selected on the primary trigger. Included are a log, the map and two scope files.
scope_20241118_213 falling.emubscp3 (636 Bytes)
Start up.emublog3 (32.1 KB)
scope_20241118_212 rising.emubscp3 (635 Bytes)
Start up.emub3 (59.8 KB)
I just had a similar problem with a subaru running in V2 and no start in V3.
To my surprise i found my Cranking Fuel TPS 2D was flatlined at -100% by default meaning zero Injector pulse.
Not a problem in this case.
The rising edge looks good. On the scope I can see spark outputs and fuel injection.
Could you please attach your V2 calibration and log from cranking.
nov 17th reviewed.emub (145.7 KB)
At this moment I only have a map that I used before but no log… if that is ultimately necessary, I’ll have to revert to V2 on the cat to get it done.
On the rising edge, I believe I was getting one or two pops out the exhaust. But no start.
Log from v3 when you crank.
A log of cranking on V3 was already posted. It’s above, named “start up”.
You are right, I didn’t noticed.
Any insight? I thought it was firing order configuration or ignition output/injector phasing
Change the primary trigger edge to rising and set invert phase in the firing order options. Should be ok.
