EMU Black PWM Fan Control - H-Bridge High Side Trigger
Hello Everyone!
I’ve been tinkering with V3.054 on the EMU Black and was wondering how I could achieve the following:
I have a 16 inch Proform brushless fan that uses Positive (High Side) PWM control. 3 wires come from the fan, one wire is +ve PWM. Other 2 are heavy gauge power and ground sources.
How do I configure my H-Bridge to control that fan directly?
  • I see no option to ensure that I am sending a 12V PWM signal to that control wire on the fan.
  • So far, I am using the PWM Table 1, with CLT on the x-axis and VSS on the y-axis.
  • Is there an option I’m missing where I can set the polarity of H-Bridge?
Thanks!
Inverting the H bridge output will change it from low side to high side. However if memory serves PWM outputs only work low side.
A pull up to 12V and inverting the table may work for this.
Thanks for the suggestion! You’re right. I’ve been researching the topic and the consensus seems to be exactly that. I’ll probably start with a 10k ohm pull up. Also could be used on any AUX or H-Bridge output.
Cheers!
