Hello all!
I have a Classic
I just purchased some Spal Brushless fans from a Chevy volt. I understand the wiring aspect (Signal wire, Ground, Power). Everything wiring is set up correctly. But I set my PWM tables and get absolutely nothing from the fans. Doing some digging on the forum here and I am missing the options under outputs-coolant fan for PWM control, PWM min dc, PWM Max dc, ect. I am curious how I get this drop down from the outputs. I am setup for aux 5 which says is pwm compatible. Hopefully I’m missing something stupid but any help would be appreciated on setting these things up!
Thanks!
