Emu black v3 open beta tests
Hello, I’m just starting a new project based on the v3 software. I’m not sure about the correct settings for ignition outputs, injectors phase and firing order.
The 4 cylinder engine is currently operated with a standard ignition coil. The firing order is 1-3-4-2. The order is fixed by the original distributor ignition.
Updates for wasted sparc, etc. will come later. Please look at my settings for this. I don’t want to start with incorrect settings right away. Thank you very much for the support.
Update: The injectors are controlled in pairs (1/2 & 3/4)
Hi, are you still giving access to the V3? Few days ago I’ve send form and I didn’t get any reply.
Is there going to be an engine oil start function in the V3 version? To shortly disable the injector and bobine so I can pump the oil through the engine.
Actually there is a table that you can define delay (in revolution) based on engine temperature.
Or you can just use Fuel TPS correction that disable fuel when the throttle is fully pressed. So when you want to build the oil pressure first just press the throttle and crank the engine.
Ah oke, that sounds like an easy solution. I will try something like that
Hi, I sent in the form for the V3 sometime last week. Still waiting to hear back from you guys
Hi Still waiting for some kind of an update from you guys
Hi Guys!
We grant access typically once per week. So please be patient.
If you do not get reply until tomorrow please send your application again, as it is possible that we missed it.
If you could please look for my application at your earliest convenience, I would greatly appreciate it. I’m trying to tune my DBW ITB classic Mini and I think the improvements made in the V3 software will give me many fewer sleepless nights. Thank you.
Also wrote an application 3 weeks ago, would be happy to hear a response :v:t5:. Wrote 2 other emails too
Tommorow you will get an access!
Hopefully me too, I submitted my form earlier today.
Hey I cant open idle valve in afterstart?
check your idle state and publish log file. Screenshot isnt useful at all
20250702_2003.emublog3 (2.0 MB)
Hi, i have BMW S50 Europe engine, i cant get it run, what do I forget?
I think the idle valve dont open in Afterstart State…
Do you need any other information?
Best Regards
Your idle goes to active state what is proper. What is your Active state air flow table ?
Please start your topic in V3 beta test group.
