EMU PNP BUB Pinout
Is there a pinout for the BUB plug in ECU with the information of all connected pins? Perfect will be if the same naming like the black software uses. Missing stepper outputs for example. Have some troubles with missing outputs/inputs and wanna see if there is another solution for.
Thanx, but these are the ones I already have. I need the description like b11, g23 etc. similar to the BFH attached
PINOUT_EMU_bfh_vr6r32_black.pdf (126.5 KB)
In the BUB pinout there is also a failure in description of pin 37. There is mentioned H Bridge, but logical will be H Bridge #2A
Hello AlexM.
Don you Haven BUB extra plug pinorder allso?
Download pinout and basemap here: Ecumaster EMU BLACK Plug-in ECUs
