Provided pinout is wrong
First, does anyone in charge with ECU masters actually look at this forum? Second. If they do, could you please fix your pinout for the spread sheets you provide to reflect the correct descriptions?
The base map for the 1.8t PnP has the check engine light (pin47) set as “can bus”. In this configuration, it works. However the pinout for the BAM 1.8t PnP says pin 47 (check engine light) is Hbridge 2B.
So now that we know the spread sheet is wrong, can we fix this to stop spreading confusion for one; second, can we disclose what pin Hbridge2B actually is please so that I may use it?
Attached the files that are found from ECU masters themselves.
BAM pinout spreadsheet v2.pdf (28.9 KB)
ECUBAMBPLG_startup_135.emub (147.0 KB)
