Hello All,
i’m having trouble to calibrate the Stock DBW on a LSA engine.
context…
Wiring is Correct - Before me, car was tuned on the same Emu and the dbw worekd, i deleted the map [=
when i move the TB by hand the the TP main signal and the check signal moves great.
but when i try to calibrate it’s seems that the TB wont move at all.
test function on the DBW section is odd.. it wont move the TB, but when i select and then Unselect the “reset command” function
it will start buzzing and will work but just a little bit, it will move from it’s parking position (24%/20%) about 2-1% tnd that is it.
same if I Unselect the H-bridge 1 and go to tools > test outputs > then select the H-bridge1b
when i select the H-bridge1a - wont move / wont buzz
iv’e attachen logs and maps.
verified
- inputs and outputs
- wiring
- voltage min and max on all sides
- different Hz frequency
- current limit
- accelerator pedal calibrated X2
- error flags check (useless… )
cannot attach file so here is a google drive link
