”EmuBlack” and ”WHP wideband knock sensor kits” on 2JZ
Wideband knock sensor was installed on 2JZGE.
I downloaded basemap from ecumasterusa.
Is the input setting correct and how do I adjust KnockFreq, Gain, etc.?
Did you figure this out?
hi.
i think should be 121212
ecumaster.com (https://ecumaster.perek.it/basemaps_view.php)
and
ecumasterusa.com(2JZ_JZA80 MK4-GS300 Non-VVT - Google Drive)
of the
The Sampling of the knock sensor is different in the base map.
Why is this?
On ecumaster.com it is 121212 and on ecumasterusa.com it is 111—.
What is ur firing order? According this the assignement must be done.
As i said above 153624 firing order nunber two sensor is a rear one so has to be 121212
PRP VR38 Coil Kit" and “FSM FU Dizzy Kit” are used in “JZA80 2JZ-GE 330cc Distributor Startup EMU Black_rev1_2.emub” of “2JZ_JZA80 MK4-GS300 Non-VVT” in ecumasterusa The following is the setup of the “PRP VR38 Coil Kit” and the “FSM FU Dizzy Kit”.
ignition
so is as i said 121212 but obviously do don’t have to listen my advise do whatever you want…
firing order is still 153624 is just different ignition offset start form event 3
Thank you. I will try that.
I asked for the firing oder settings cause it is significant for the knock function. Without having this information the knock sensors can’t be assigned and this information wasn’t yet shared here.
But yes u are right.
