I went to the dyno to tune the engine to 98 octane gasoline and ethanol with software version 216.0.1,
I filled the corrector with the etahanol percentages and I made 2 mappings to be precise up to 5% and 60%, did I proceed correctly?
It also seems to me that the correction percentage only acts on the first map at 5%, and that the VE-tuner always acts and corrects on the first map when it’s on the 60% map, which means that it applies the corrections to my petrol MAP when it detects 70% Ethanol.
Can you tell me if I’m making a configuration error or if it’s a software error?
Thanks for your answer, I’m more towards 8 to 10% difference in EVs.
Is my ethanol correction table more or less accurate according to you?
So do I have to change the density each time between fuels or make a table like on the picture?
Best regards Yann
Thank you for your answers, I understand, I’ll try according to your information and if it’s not precise enough and I want to make VE tables, I have to set the Ethanol table to 0 everywhere and work on this VE table, for example 5 tables every 25%?
Does the VE tuner always correct only on the first graph or should it normally correct where the cursor is as in the photo, if the cursor is on 70% it should correct the 70% graph?
Because when I did the programming and the two cursors were on 70% on the VE and the VE tuner, it corrected the first 5%?
Thank you for your answers. Yann
