Flex fuel and high/low boost switch
Hello everyone
First post.
Question. Is the BLACK able to blend boost with ethanol content as well has have a high/low boost switch.
Thank you in advance
I was dyno tuning a Mk4 Supra on a Black this weekend and was unable to figure out how to get boost to blend tables based on ethanol percentage. The only way I could conceive of doing this would be to set up a few virtual outputs based on ethanol content percentage ranges (0-20% as VO1, 20-50% as VO2, 50-65% as VO3, and so on) and then use the output activations in the blend axis or something.
Did you check “blend boost tables” in flex fuel parameters?
