EZ30R swapped impreza running emu pro 8, difficulty starting/running please help
Ok so working on this impreza with an h6 ez30 swap. Thought that an emu pro 8 would be the choice to go with but having second thoughts. I cant seem to figure out why this wont start or stay running.
It does start, but its inconsistent, it will randomly fire up run for a second or two then die. When it does run it seems to run really well. Other times it will just crank and crank then try to catch and backfire. I am not 100 percent positive on if my trigger settings are correct and if I may be missing something super obvious.
Stock 270cc injectors, gm2 bar map sensor(vehicle is not boosted), intake and exhaust. Individually activated coils and injectors, they are wired correctly and assigned correctly. I cannot upload the map sadly because i’m a new user but anyone that is willing to take a look I can email you the map and log.
You can upload it to Google Drive or something like that.
Then, post the link here.
Or you can send the project, log, and scope files to me:
marek.kuklis@ecumaster.com
Thank you so much for the reply, I sent you an email. I’m more than certain my trigger settings are wrong.
