Hi…i have a problem with emu set firing order to a 2 cylinder motorcycle with 270 degree crankshaft…any help please?
run it as v8 and select appropriate events.
Hi thanks for your reply…emu has 6 ignition outputs
doesn’t matter i’m talking about events and you need only two outputs it has been done multiple times
Can you tell me which output must set to cylinder 1 and cylinder 2?
Thanks you very much for your help
Hi.can you help with injector phase cylinder 1 and cylinder 2? Its like ignition events? Injector 1-ignition event 1 and injector 2- ignition event 4?
