GM battery current sensor 13505369
Would be nice to add in the digital sensor list the Battery ( or alternator) GM sensor 13505369. It can measure +/- 60Amp, and is very cheap. Is a digitak signal, at around 128 hz with varaible duty cycle. The duty cycle will determin the current proportionaly with 50% dury meaning 0 Amps and a rnge from 5 to 95%. value below 5% or above 95% are for diagnostics.
I found different occasion where would nice to have a generic digiatl input that can log and allow you to read frequncy and duty
delco_remy_remote_voltage_control.pdf (1.0 MB)
Encosing another some info i found, about LINbus based battery sensor. Would be nice to add.
Generic logging of freq/duty on inputs would be useful for sure.
