H-bridge outputs usage
Is it a good idea use H-bridge outputs as supply for lambda or 12v crank/cam sensors? Has anyone tried it yet?
Hi, I personally use one H-Bridge output to power Crank and Cam Sensors and it works as expected.
Thank you…now im testing on BMW M54 engine crank/cam and lambda sensor powered from H-Bridge outputs and it works well but im prepared wires from fusebox because I had no confidence in it :slight_smile:
