Haltech IC7 CAN (Oil Temp)
Something funky with V3 and Haltech IC7 Dash’s and the CAN message/offset relating to oil temperature.
ECU reports 19°
Dash reports 59°
I got around it by using the Fuel Temp input in V3, and renaming fuel temp to Oil temp in IC7 - now the values match between programs.
All other values match between ECU and IC7, it’s just Oil Temp.
On downgrade to V2 software they match.
will be fixed for 3.038 version
Will V3 take input data directly from the haltech ic7?
I didnt see the the IC7 output CAN protocol. If it is just plain CAN based on separate messages it should be easy to use user CAN to do that.
