In the EMU PRO8, how can the MAP values of the two cylinders be adjusted separately to change their fuel injection volume? Also, can the engine’s cylinder shutdown technology be implemented in the software? How should it be set up? Please give us some guidance, seniors.
20250522-1.emupro (27.6 KB)
Use two banks for engine volumetric efficiency.
You will have two VE tables.
There is no direct strategy for that.
However, you can make a custom per-cylinder fuel correction to cut the fuel depending on your conditions.
