Single cylinder EMU PRO setup
Hello
I am currently making setup for an KTM 690 Duke on EMU PRO and I do not know how to make it possible to use 2 coils for one cylinder. When I try to setup one cylinder there is restriction of 1 ignition output and It requires 2 cylinder to use 2 ingition outputs.
I think about using 2 cylinder setup with a wasted spark to make 2 coils work every time, however i do not know whether it is correct solution. Is there a better or correct way to do this?
Also, i heard about requirement of CAM sensor (instead of CPS only) in order to properly trigger synchronisation in EMU PRO - is that true? I can understand that it is needed in sequential fireing order however i do not think this applies to single cylinder - dual spark setup.
you can assign a second coil to a cylinder by using the Trailing spark function.
Set the delay to Zero to fire them at the same time if this is wanted.
regards
Bastian
