Looking for advice. Second EMU pro install where IAT and EGT haven’t worked.
IAT to Ain and analog ground
Cal table set up, voltage seen by ECU which correlates to expected temperature but no display of temperature. Tried new sensor too.
EGT to Aip and analog ground
No voltage seen by ECU and no temperature read out. Tried swapping wiring round but no luck
Done continuity through wiring loom to confirm it’s an ECU/software issue.
It’s strange it’s 2 installs that have the same issue. Especially IAT that sees voltage.
