Ign1a setup on Classic
Good morning, this is my first installation of an Ecumaster product.
Emu Classic wired to ign1a coils. In an Alfa Romeo Nord 2.0 using Jenvey Heritage ITBs. Wired following the manual.
ECU registers RPM and synchronizes instantly; injectors pulse, but got no coil output. Confirmed and rechecked wiring, and voltages/ground presence are o.k, but using the scope, saw no signal coming from the ECU.
The only parameters that I found and configured are Coil type: coils w/built-in ignitor, Coil output assignment, and dwell configuration. Is there anything I’m missing?
Thank you for helping a brand-newby
Have you set the firing order?
There is a first start checklist here which you should read through Software and Documentation
