Hi all i need help please. Anybody know, how its conect and adjust correct this ignition coil for emu Classic? Please step by step? This ignition coil have 3pins Connector. When i use this setup and perform test, the coil starty warm up.
Test in ECU, Tools-test outputs-output- ignition out #or2. (In photo)
But a main problem is, when i conect a connector to ignition coil, ECU start warm and same a igntion coil. One igniton coil is damage after one engine run-up, i replace and i have same problem with new coil. This coil have 3pins. +12v and signals from ECU(conected on ignition coil #and#2)
After 2 days of troubleshooting i found a problem. Ignition #1 pin on ECU signal its grounded- problem on the ECU, i must send to warranty. When i conected wire to other Ignition pin, all function its OK
