Hi, Is it possible to change these to a 3d table? I have done a number of BMWs with 6 lambda sensors and the amount of imbalance between cylinders is quite an eye opener. But its never the same % over the whole VE table, I’ve seen as much as 20% on a single cylinder mid throttle and mid rpm but then equals out higher rpm, so as it stands at the moment a single percentage increase wouldn’t work.
right click and modify axes and y axis wizzard is already there
Sorry, got it, I was on an older firmware.
