Hello guys!
My dad and I are having a lot of trouble on tuning my project car. We seriously couldn’t get the thing to start up or sputter at all. The most we got were some backfires and halfhearted chugs every now and then when we had it running with batch all injectors. But anything else? Nada.
I was hoping anyone here has any experience or input to get this thing running. Its so close to running I can practically smell it! (Literally the whole garage full of gas smell)
Dad and I are going solely off of our own knowledge, forums, and manuals but no luck
What injector phase would be needed?
Any help is appreciated!!!
Important things to note:
We get test outputs for all injectors, and only coil 1,2,3 but not 4,5,6 (is that normal?)
I have the 36-2 crank gear but one of the crank position sensor wires are shorted so we’re running the primary trigger on the dizzy gear instead.
Is 24 teeth the correct setting on the primary trigger for that gear, we counted 24teeth but on scope we only get 24 ticks instead of 48 between cam signals (is that also normal?), however I do have base timing set on 10deg BTDC
Its a 1996 SC300 with:
- 2JZGE NON-VVTI
- Distributor to VVTI wasted spark coils
- CX-RACING turbo kit on it
- Walbro 450 fuel pump (not installed yet)
- Stock 1996 2JZGE injectors
Thanks everyone!!!
I can’t attach files just yet because I am a new user but I’ll do my best to describe anything to anyone until I can and provide these links below
[SCOPE]
(upload://z2wxHJUgr8imUEmaCvaZIaZz3US.png)
[LOG]
(upload://23x1r5zfR243bJq0LfwdwNPJfkS.png)
[Logs tab]
(upload://kn25hBf4OErwQkqPoqwm99CwNQO.png)
[Cranking tab]
(upload://vyEinQO30rHewSPOLiPAh6sAbJY.png)
[Triggers tab]
(upload://hJ13nFvPZZUgIIn9LpMq02Kgykz.png)
[Ignition tab]
(upload://gHZJSfbYIwgKG6qVWMqfBfmislE.png)
[Fuel tab]
(upload://t8nh29Fb5cKx4cuj9kmpHHkX0ZQ.png)
[Idle tab]
(upload://y7HafSCMHZkAQsNjKkL9JpZBEpU.png)
[Boost tab]
(upload://usrBC49xU6IM5bGxce6YhSq00EA.png)
[Outputs tab]
(upload://7pV3y0IiogBcDdPOu4Y9eU5yFcM.png)
