Issue with my can am maverick, crank but no start, desperate
I should say that before it stopped turning on it was running but was having an intermittent problem where it showed low oil pressure. The engine is in good shape so I’m not sure I believe the sensor. This whole build was done pre covid so maybe the sensor is going out but thats a whole other issue. I’m coming here because everything is on the standalone and I dont know if people on a can am forum will be able to help as well. After changing the oil it now will only crank. The fuel pump is not turning on so I bypassed the ecu and gave the pump power, it still will not turn on. Getting to the top of the engine is quite a task but im pretty sure i do not hear injectors firing and its possible ignition is not working either EVEN though all of these items do show power at the fuses. Its like the ecu is stuck in anti theft mode or something. I have tried cleaning all my grounds and that did not change anything. Unfortunately the calibration is locked so I cant see it but it was running fine before this so I know its not the tune. What can I check? I have the emublack software. 2018 can am maverick x3
