I think I have everything setup correctly but I am trying to use analog 1 to trigger ac idle up. I read in a few posts that 12v will work for a switching application. I verified that analog 1 sees the 12v (reads only 5) and it does. I think i must have something simple not setup correctly. Tried to attach my tune but new members are not allowed attachments.
Thanks in advance for the help
Update I have discovered my issue. Wouldn’t activate because the pressure min needed to be set to 0 in order to activate without a press switch. I also ended up using the cam2 input since it was unused to input the 12v. Hopefully this helps someone else.
