K series Cam trigger settings vvt not working
On v3 my cam2 does not follow cam2 target. It only reads what my cam offset is set to.
I started with the base map from ecumasters for the pnp adapter. I had the car running on v2 and it would follow as it should. The car has been tuned on v3 now, but the cam will not follow cam2 target and only reads the offset. It used to read 0 when it started up and would follow the target. The available trigger settings for cam2 in v2 software seem to be different than v3. It doesn’t have the option for hall/optical in v3 on cam2. Any help or guidance would be appreciated
Do you mean Rover K series or Honda K-series ?
Publish your log, scope and calibration.
You setup digital inputs in Sensor and inputs section
Sorry, Honda k series. I misspoke. I set it up as a hall sensor, but under triggers it doesn’t have the same trigger type as v2. On v2 it was set up as a multitooth. They don’t have that option in v3. Cam2 is set up as “do not use” in my tune right now, but when I choose the Honda option, it still doesn’t follow.
I tried to upload my tune and scope, but it says “sorry new users cannot upload attachments”
If you can’t upload files, use a file sharing service like WeTransfer and paste the link.
You can setup trigger using trigger wizard:
When honda k20 trigger setting back ? in 3.061 there is`t honda.
For K20 engine I reccomed use the latest firmware as there is some improvements for decoding N+1 signal for high compression engine (easiest engine startup)
